Good evening,
I have had my A1 a month now and have had no real issues with the printer in any way. However today, with a new print the a1 would return to the cleanout and runoff filament every couple of lines. I stopped the print and found the Reddit Article referenced below. The fix offered setting print sequence from ‘by layer’ to ‘by object’ works but I would rather not keep this setting configured this way and would rather find a fix that allows me to keep the By Layer setting. I have tried different projects both custom and from the maker site all resulting in the same behavior. I have also uninstalled and reinstalled studio.
The issue did show up first while printing. I havent tried sense thinking that the travel showed the same issue. Testing Now, I will follow up with the result.
Hello,
I found this on bambu wiki.
You will always see the travle time but if you dont check the box on from Timelaps when you send your design to your A1 it will not do the travel time.
