Put aluminium tape on the inside walls of the chute
100% fix, thank me later
Why does this help? What is the idea behind?
From what i can tell, it’s because melted material sticks to the plastic of the chute. PLA sticks well to plastic and doing this prevents poop from sticking and with that, it goes directly down.
I have tried with a p1s already a few months ago and can confirm it works much better and at least the chute doesn’t clog or fill with poop over time.
There is already a small metal plate in that area. I think it serves as a sort of heat sink to quickly cool poop and prevent sticking to the walls of the chute. Sometimes poop curls and twists, and misses the plate. The aluminum tape expands the size of the heat sink to deal with the occasional times when you don’t get the straight poop.
Great Idea Im trying tomorrow… hope it works… been a real pain in the ass sticking to chute
Need a silicone lined chute
I’ve had my share of flung poop just because an old one was stuck. I’m thinking of lining the inside with PTFE spray to prevent anything from sticking, but I’m not sure how well it will work.
Dry PTFE spray is what I use. I reapply lightly every time I do maintenance, no problems since
Nice, I’ll give that a try. I use it a lot in my gyrocopter, so I know it won’t cause any issues with flying objects, at least. ![]()
Do you remove the chute entirely to spray and coat it?
G*n oil worked for me ![]()
Anyone tried kapton tape? Should work too, IMO…
I used a mix of high temp Teflon tape and some Dry PTFE spray, did a 49 hour multi color print and had zero issues though, I had soooooo much poop so if you have a really wasteful print just remove the container you use to collect it and let it fall in the floor and sweep it up otherwise it can still stack up overnight and clog.
