Possible to Build an Half AMS Lite 2Spool Setup?
I own a A1 Mini and A1 with 1 AMS lite. Awesome Printers, super easy to use with my Kiddo.
So i was browsing the parts section for AMS Lite.
If i was to buy:
2x AMS lite Rotary Spool Holder
1x AMS lite Feeder Unit 1 2
1x AMS lite 4-pin Cable
1x AMS lite Mainboard
Could I Technically piece together a Half AMS Lite ?
Will the control Mainboard throw a fit, for not seeing the NFC coils and the missing 3-4 Feeder unit ?
I mainly only need 2 colors on my A1 Mini lack some space, so I was debating on this project but was unsure if the elctronics would throw a fit.
I think it’s a win-win project so to speak. If it works as your intending, then AWESOME! I think it would be super awesome to have only a 2 spool mini lite just for support materials etc.
If your idea doesn’t work, then you have spare parts etc for your existing ams units.
Good Point, Does the AMS lite have parts that are more prone to failure overtime or is it mainly depending on user error ? I see random failures to feed or to recognize, with now distinct patterns of failure points in the forums.
Update and i am excited !!!
I have received my parts.
To my surprise everything plugged together smooth.
BOM so far:
-AMS Lite Board
-AMS Lite Feeder Unit
-AMS Like 4 Pin Connector
I had 1 extra PTFE tubing so I didn’t need to order new tubes.
I didnt care for NFC ID yet at this point, maybe later in the project.
Some interesting things happened when I plugged everything in.
  1. Unit asked to update the AMS Lite Motherboard instantly, started flashing red briefly and finsihed updating.
  2. Went through the menu and loaded up fillament, everything acts normal just my slot 3 and 4 show up as empty
  3. Test Print went smooth.
So next on the to do list is making a Housing for the electronnics and the Feeder to attach to !!!
Time to do lots of prototyping !!! EXCITED !!!
Interesting project.
Budget wise you’re already at 136€ or something like that , right?
It would probably make more sense to buy a A1 mini combo. The AMS cost 150€ when bought this way.
If you have only one printer you will have a more extensive list of spare parts.
And if you have a second A1 series printer. You could build an extra Mini AMS lite for 62€ (MB and cable).
So in other words 2 Mini AMS lite for 212€. Really interesting :slight_smile:
Yeah price was not my original concern rather than space and then retain features as my second printer in a different location. It can be done cheaper, alot cheaper if you find a used or damaged AMS lite donor system. It will be interesting =)
I have same plan, I want separate my AMS Lite to two, with top mount and save (use) all parts from original AMS, may be someone make model for print or can do this or maybe you sen somewhere?
I am desinging my own. Will be posting once i have finalized it, though i have been bz with work so it will be another week before i get to to pit 100% of my mind to this project.
what cable did you use to connect the AMS board to the feeder unit?
The Feeder unit comes with a cable that goes to PCB
This setup uses half of the the AMS lite relocator.
AMS lite spool adapter with a Green Reverse Spool Holder
I made a custom Exstension to move the Feeder over.
My Second Feeder usually pulls direcly from a Drybox for Support,PETG or TPU.
Makes swapping fillament much easier than plain printer.
Great job, thanks for sharing! this is great for small spaces. I ordered it as well and will do the same.
strange that they come out with a mini 3d printer and no option other than the bulky ams lite. I am pretty sure there is a market for this.
did you create the 3d print for the feeder unit & AMS board yourself?
Did you share somewhere models and instructions?
It is based of this, The PCB shell and Z Axis Cap will work. I have made my own top cap which I am still modifying to do some relocating.
Since I am only using one Feeder head, this is my Plug and Relocator adaptor.
My Version of the Spool Adaptor for Green
Other spool holders I have tried but their green version did not work for me.
Brilliant stuff, I only need multy material for support interfaces so I was think about the exact same thing. But could not find much info on the internals of an ams lite. I’m gonna try this now.
Exactly what I wanted. The parts arrived yesterday, I hooked them all up, and it works!
This is pretty cool. Anyone have links to prints for fitment on an A1 instead of the mini?
I do have an A1 but I am using my normal AMS with it lol. I needed this more compact solution for my A1 mini. But I did see a setup that securely revamped the AMS top mount to a more secure setup on top the A1.
Did put an order in for:
1x AMS lite Rotary Spool Holder
My savings is 42% lower than bying a new ams lite, yes there is only 2 spools, but that is fine for me at this cost.
Hi everyone, does this still work? I want to “split” an ams lite in two pieces or if its cheaper just buy the necessary parts to build something. Thx
