PPA-CF dryer
I have Sunlu E2 which goes up to 110*C. What are my best options for properly drying engineering filaments like PPA or PPS? Kitchen oven? Sunlu E2 or something else?
What is the filament usable on h2d that needs highest drying temperature? I am a bbuy once, cry once type a guy. What is my endgame option for filament drying? Yess i know i can get an electrical oven that goes to 2200*F (its on my list), that is not the question here.
Thanks
Go to goodwill and pick up an air fryer that is able to hold a spool in the bottom.
With properly regenerated desiccant and 85C you can dry the stuff just fine - it just takes a lot longer and you have to keep that RH low. Like, well below 10%.
That just takes a lot of good desiccant and it’s no problem. I’ve been actually having perfectly usable results with an 85C printdry unit that I have just been alternating big bags of microwave regenerated silica into every couple days.
Temperature control in cheap cooking appliances is not particularly exact, but it’s still a good idea. A good bakers oven will be accurate, but you can probably get a smaller laboratory oven for less money.
Probably PPS/PPA which are suppsoed to dry at 100+
Some people claim you can print PEI but I remain unconvinced.
your h2d’s heatbed can do up to 120 degrees, no need to buy anything
I already have sunlu E2, which goes to 110C, Print bed going to 20 probably won’t get filament up to 110. I was smart enough to have never purchased a wife, hence kitchen oven is accessible, but unlike Sunlu E2 it does not vent.
Not a snowball’s chance that will heat soak the entire roll properly.
How many days do you want to leave it?
unless you cover it properly
What is wrong with the Sunlu E2? That dryer is one of the hottest on the market.
100C for about 8 hours should do the job just fine.
I had ppa-cf in it for 20 hours. still stringy print.
Heat alone is not sufficient to properly dry any filaments ever made. Fully dried, regenerated desiccant goes a long way towards drying it properly. Easiest way is to heat soak the roll for say, 8-10 hours at the drying temp, then while it’s still hot shove it into a room temperature drybox with a mountain of fully regenerated silica for another day. Try not to melt you drybox.
Now, I before the pitchforks come out - many materials can be dried well enough with just hot air, and this leads to a certain perception in this community regarding drying. PLA is the best example. It is so forgiving of moisture that people learn a lot of… less than optimal habits when using the stuff.
PPA is less forgiving, and hot air alone is largely insufficient.
How do you feel about vacuum drying filament?
One of the fastest methods. Pretty energy efficient too. Sometimes.
Its extremely effective and I keep meaning to try it out as I’ve got a freeze dryer at home so I could, in theory, preheat the spool then toss it in there and pull it to a nearly hard vacuum.
Never use a kitchen oven–unless you never plan to cook food in it again.
The last thing you will want is outgassing toxic plastic in your meals.
Also, kitchen ovens generally do not hold a steady-state temperature, but cycle up and down.
You can just buy a lab blast oven (used or new) something like this…
At $5400 for OV4-30, STS i can just buy a good quality electric kiln for like $3200…
After 12 hr in sunlu e2 i ssee 0 weight change, went from 1054 to 1055 grams, i am not saying it gained a gram, guessing round-off error, but definitely did not loose any weight. Trying vacuum chamber next.
Ah, I see that, but my point still stands. I bought a small blast oven on eBay for under $200 awhile back.
Look around. You should be able to find something.
An airfryer should also work great for higher temperatures. Ours keeps temperature stable within ±3°C. It also slowly releases the moist air outside. And the high airflow certainly is helpful too. Only adding desiccant might be less efficient due to the constant exchange of air.
