In OrcaSlicer,Can I take the pressure advance calibration number and plug it into the filament profile, and skip selecting it on the device page for every slot in the AMS? Apparently Bambu Studio has no PA setting in its filament profiles anymore.
If I add PA to the filament profile in Orca, will BStudio use that value, or default to another?(ie. G-coded value, value saved in AMS)
I almost always use Orca, but want to be sure I’m using the calibrations Ive gone to the effort to collect, if I use BStudio.
I have 2 X1c now, and syncing the AMS units to filaments is flaky when using the device tab to flip between printers. When doing so, one AMS always forgets its filament values, and only a restart of machine and Orca will allow me to re-select correctly.
If I could save the PA value in filamentr profile, I could eliminate this problem.
Or maybe Im doing this wrong, please advise me.
Studio will NOT use the PA (K value) from the OrcaSlicer filament User preset. The other filament settings are shared and can be kept in sync through the Bambu cloud, but Studio will ignore the PA setting added by OrcaSlicer, using only the value set on the Device tab and saved (or not) on the printer/AMS.
If you slice with OrcaSlicer, the PA values stored in the filament profile will override any that are saved on the printer/AMS.
Unless you are big user of MakerWorld, I don’t see any advantage to using Studio.
Exellent news. I use Orca as my preferred slicer, and I prefer simplicity. I don’t use Makerworld to print from.If I see a model I want, I’ll download it, and slice it myself.
Thanks for the reply, I appreciate the info
