Using A1 with two filament colors. Bambu Studio. I would be grateful if anybody can help ease my confusion…
Under Preferences there are settings for auto-calculate flushing volumes. How do these settings affect/interact with the prepare/preview (left hand side - filament) “Flushing volumes” settings? Does the “auto-calculate” refer to auto-calculating mid-print or what? Is it just referring to whether or not you want the values in the flushing volumes box to automatically change when the filaments/color spools are changed? (Why would the calculation be different if you changed a filament but did not change color?) I am a little confused here.
Is there a good reason the prime tower is so far away from the print and unmovable? Would it not be sensible to have it close to the print to reduce travel distance between tower and print?
Is “purge” and “flush” the same thing? If so, why are both terms used within the software? It seems we also have “wipe”. Is that different?
This is my main question. With prime tower turned off, the flushing volumes can be set down to zero. With the prime tower on, regardless of the tower width and volume settings, there appears to be a significant minimum flushing volume (listed under “Flushed”, not “Tower” in the Color Scheme box - Filament) that cannot be avoided (unless you “flush into this object”). Regardless of reasons why you might not want to, why can the flushing volumes not be set down to zero with a prime tower?
Why does the software insist on a prime tower if we want to flush into support or infill (again, regardless of reasons why you would want to)? Is this the same reason why there is a minimum flush volume when tower is turned on? It all seems a bit unclear to me.
Thanks.
