"Print all" button - what is the purpose?
Hi :v:
I tried to search online and here in forum, but I can’t find any info about “print-all” button in Bambu studio. When I use it to print on my A1 mini only one of the plates is printed (what else :grin:) and when it’s finished there is no message suggesting to print next plate or something. So what is it actually for? Is it for users with multiple mashines?
It’s easy to forget that this slicer was forked from Cura an Prusa Slicer. There are many, many … and I mean many, obsolete or Vestigial or irrelevant functions that during the porting process are simply left in because it makes debugging easier.
I investigated the Print-all function a while back because I too was curious. The sole reference that I saw that made any sense was for a belt driven printer such as this one from Creality. I’m sure there are more. But you can see the use case. If you have let’s say a large build with multiple plates, one could simply load up some larger spools(i.e. 5KG) and just walk away from the printer for extended periods of time and let the parts fall off into a collection bin.
Here’s the kick starter video from Internet Tech phenom Naomi Wu where she describes her use-case for adapting the CR-30.
Oh, ok. Thank you for your answer! Do you know or have an idea where (from which slicer) this function came from to Bambu studio?
I’m a co-developer of a plate swapping automation system called JobOx (https://www.youtube.com/watch?v=_94lo33rUQM) . We initially built it for Prusa printers but now we are developing also one for A1, so I got curious if this “belt functionality” is implemented in Bambu studio in some way.
Unfortunately I do not. However, if you’re motivated to find out and don’t mind going on an Indiana Jones archeological dig for previous context, I would start by posting this question on the Github repository for Orca Slicer which likely will have the most friendly environment.
You could also try Prusa Github or Cura Github discussion pages but both are sponsored by their commercial namesakes and you may find that they may not be as receptive or may view any outsider as not being in their best interests. Whereas Orca is a group of independent hobbyiest precisely looking for like-minded enthusiasts who want to extend the function of the slicer.
Thanks for the advice, Olias. I have had the same idea and already tried contacting SoftFever on Discord and posted a request in the dev community describing and illustrating some thoughts of a real “print all” implementation. Let’s see what feedback I get. I believe A1 with it comparably small build surface could benefit from automated plate swapping upgrade.
That would be a cool upgrade indeed. Yes, please share your progress, this is a genuinely interesting project. :+1:
Thank you, I will. :slight_smile:
you mean this?
grafik
Yes. In the meantime I found the difference between “send/print” and “send/print all”. Second will generate a 3mf with multiple gcodes inside while first option will only include current plate. However, it is not possible (at least not on my A1mini) choosing which plate I want print, even when “send all” was used . Only possible through a hack with some “magic words” (MQTT commands).
As far as I know when printing all plates, the printer prints the last plate. After finishing you press “again”(?) and the next plate is printed.
But very intuitive
Wow, this is weird ^^ Thanks for the hint!
Have you figured it out accidentally or have you found it in some official documentation? Because I haven’t found ANY info so fat. :S
Can anyone else confirm that here?
That’s how it is going. You are right.
Maybe it was so, but not anymore. Yesterday after an update of Bambu network plugin I tried using the “print all” function and it says my printers (a1 and a1mini) are not compatible with this function. Which is quite unfortunate (at least for me). I developing an automation system which used this function for multi plate print. It was just hitting “print all” button and the printer prints all the plates in the file one by one ejecting the full build plate and loading the new one from an magazine. Was a real game-changer in terms of usability. But now i need to find a workaround for this. :sob:
Have you tried this on a recent version of BambuStudio or Orcaslicer? If it still work, which printer are you using?
Short update about a progress: Automation hardware for A1mini is ready. (An other team who works on similar automation for A1). My prototypes are in alpha test stage right now. Works quite smoothly. Software which manages the printing queue is finished by about 80%. Backend works and can already run print jobs in a loop until the magazine or filament goes empty. Frontend and UI still in work. However I’m quite concerned about the announcement of BigTreeTech a while ago claiming that BambuLab planing to shut down current MQTT controlling interface of their printers in the near future (which I’m using). Not yet officially confirmed by BBL but that makes me a little unsure about my own release plans. :confused:
That would be a pity, because I think fantastic solutions come from the community and that further increase the popularity of Bambu Lab. Turning this off would be stupid and would prevent Bambu Lab from receiving legend status at some point.
Well, I forgot to mention that BTT also claims BBL would establish an other communication interface and provide an official API (one day) which is actually even better in a long therm. But in a short term it will temporarily stop many projects and cause some uncertainty according the release planes of many developers.
Here is documentation that explains how to use “Print All” in Bambu Studio:
Links are not allowed, so search for this with Google:
Bambu Studio Multi Plate Printing Guide | Bambu Lab Wiki
Just wanted to acknowledge your word of the day!
From 2023
