Print bed stuck
The print bed of my X1C is stuck at the bottom of the chamber. How do I fix this? Should I push the home button?
X1 series Maintenance and How To guides | Bambu Lab Wiki
Have a read see if it helps , there are a couple of heatbed sections
Welcome to the forum.
Homing should bring the bed up. If it doesn’t make sure that nothing is jammed in the belt underneath the printer.
Did anything happen to cause it to be stuck? Did you remove the screws (in case it is a new printer)?
If in doubt, you can also turn off the printer and move the belt or spindles by hand. At least that should tell you where the problem is.
Its fixed. The printers are in a school computer lab and someone got plastic shoved in the belt and caused it to get jammed
