Print different colours at different speeds
Hi,
Is it possible to change the printing speed for specific colours? I’m printing a design with 2 colours. One of the colours is for small details, but the finish is a bit rough, i think it’s because of the speed.
thanks for the help.
If you press the little pencil by the colour you want to slow down then there are a few settings available. You could try reducing the ‘Max volumetric speed’.
Should be able to verify that it is working by selecting the ‘speed’ option from the preview screen - I would suggest doing this before, try a screen print, then try it again after changing the setting.
WOW, that’s awesome. Thanks. It skipped my mind to do that, but I can make it really slow based on the speed in the preview window. I hope this works. I will let you know, but I’m sure this will work well now. Thanks a lot for the input.
