One thing I noticed straight away: your filament is bone dry, which is great! So we can rule that out as the cause. Even fine details like these come out perfectly:
One thing you could definitely optimise straight away: don’t put everything on a single build plate. At least print the taller parts separately, so the nozzle doesn’t have to keep travelling back and forth between them all the time:
Your objects don’t have a brim, which isn’t ideal. I’d definitely enable that. It’s not the solution on its own, but it’s another piece of the puzzle we’re missing:
You’re also using the Extra Fine 0.08 profile. While the printer is theoretically capable of handling it, I’d suspect that, given its age and the number of printing hours, it may no longer be operating quite as precisely as it once did. As the print gets taller, this could cause the nozzle to start hitting the object.
Combine that with the constant travelling back and forth between objects I mentioned earlier, and you could end up with a chain of events that eventually leads to print failures.
Personally, I’d go with 3 wall loops instead of relying on that little bit of infill. It might not be the cause of your issue, but it only uses a few extra grams of filament and gives you a bit more substance. That’s just my personal preference, though.
Your settings:
3 wall settings:
Also, make sure you calibrate both your printer and your filament if you’re going to push the machine this close to its limits. From what I can see, it looks like you haven’t calibrated the filament yet?
Your settings also differ from what the manufacturer recommends on their website: It’s not a huge difference, and probably not the cause of the issue, but you should still make sure your filament is properly set up and calibrated.
To sum it up: I don’t think there’s one single culprit here. It’s more likely a combination of several factors:
- Print one object at a time instead of having multiple on the build plate.
- You’re using a 0.08 mm layer height, but after all those operating hours, the printer may have developed too much mechanical tolerance to handle it reliably.
- Use a brim, ideally at least 10 mm wide.
- Calibrate both your printer and your filament
- Personal preference: Use 3 walls.
And in case you’re wondering whether there’s anything you can do about the tolerances: check that the nozzle is still firmly seated, or more specifically, that the toolhead screws are properly tightened. Also check the belt tension.
I’d also lubricate the Z-axis rods. If they’re not moving smoothly, even the slightest bit of sticking can be enough to cause issues at 0.08 mm layer height.
Personally, I would consider whether 0.12 might actually be sufficient. Or even take a completely different approach with 0.16 and refine it, either chemically or mechanically.
