Print not using filament profile defined nozzle & bed temps
Fairly new to Bambu Studio. I have a custom filament profile setup that uses 255 first layer and 245 other layers. It also sets the bed temp at 70. But when I slice and print it sets bed temp at 80 and does all printing at 255. Is there some place the temps are being overridden? How can I set it up to follow my defined temps in my filament profile?
I had the same problem (and I’m using Sunlu spool, but don’t think that should ignore preset).
I found a solution, or at least a workaround. If one selects the model object in prepare tab, you can right-click on it and change the filament there. Or, simply press the number of the slot with the filament you want, e.g. “2” for slot 2. This works.
