I receive an error when trying to upload to MakerWorld:
print profile did not pass slicing test. Please make sure the model is sliced normally on Bambu Studio before uploading.
I literally just sliced and printed the model.
Any thoughts on how to fix it?
I’m using Bambu Studio version 1.10.1.50
Neiljt
April 29, 2025, 12:29pm
2
Updating may be the answer , if you are not* getting a prompt when you open studio
jetpad
April 29, 2025, 9:45pm
3
I’ve had problems like that when I upload a profile having a print sequence by object instead of print sequence by layer.
I did check that. It was set to print by layer already. Thanks.
I updated BS. Reslicing the file with no changes resulted in the following error:
flow::spacing() produced negative spacing. Did you set some extrusion width too small?
I used the Arachne wall generator in the original file/profile. I bumped up the minimum wall width from 75% to 85% and resliced. No errors this time.
I was able to upload the profile to MakerWorld with no issues after this.
Only had one issue with uploading a 3mf , similar error (failed slice test) because id somehow managed to duplicate a part (cad),that was in the same place as the original .
I dont know if it is still an issue, but maybe someone will beneift from this:
My issue was, that my “Wall loops” setting was set to 3, when I set it to 2 it sliced perfect.
