Print Profile Not Published
When i try to upload a print Profile, i get the following error:
Your print profile “0.16mm layer, 2 walls, 15% infill” for “Invisible Wall Mount” did not pass the slicing test. Please make sure the model is sliced normally on Bambu Studio before uploading.
I published 5 print Profiles succesfully, but this will not work and it slices succesfully in Bambu Studio.
Do you get any slicing errors? What version of Bambu Studio are you using? Is this your own model or someone else’s?
When im slicing it local in Bambu Studio 1.9.7.52 i get no error and got it printing.
Just when i want to upload the print Profile MakerWorld is giving me the error and it failes.
Its someone elses Model which had no Print Profile.
Can you share here one of those problematic profiles?
You are normally told in red text under the failure notice why it failed.
Can you provide that information, a screenshot or write it out.
As already pointed out, if you provide the profile hear, someone will take a look for you.
No one here will steal it and use it for themselves as we are all anti thieves and if someone was stupid enough, the rest of us wouldn’t let it stand.
Possible issues in the profile are:
  • Empty build plate
  • Custom filament settings embedded in the profile
  • Custom printer embedded in the profile
  • Corrupted file
There are more.
Hello,
thanks for the response,
here is the profile and a screenshot from the MakerWorld error:
wallMount.3mf (100,9 KB)
i experienced this several times last week. I wasn ´t able to publish somne print profiles because of this exception.
Did you upload it again as suggested?
There are some problems with the upload process right now that are being investigated and there is hope they will be remedied in an update next month.
Hi,
yes i uploaded it several times this week but i get the same error.
Today is one of these days again.
No print profile upload is working so far today.
I hate these days.
Exception errors, likely upload delays in verification queue hell.
I can’t wait until they fix the bug due this month.
I invested some time and looked at the whole thing in detail and also wrote to Makerworld support.
There are models where you simply can’t upload a print profile.
I took all 3 print profiles, changed the photos, changed the description, changed all the slicer settings in Bambu Studio one by one. I even tried to upload the models with default settings in the slicer - without success.
While I was able to upload other print profiles in the meantime, for some models it is simply not possible.
The only thing I have noticed that these 3 models have in common: They basically need support to print well. But even without support in the slicer, uploading is unsuccessful.
Support replied that there was a time restriction in Makerworld’s internal slicer - but that can’t be a reason either, because a day later - without having tried again - I still can’t upload the print profiles.
Could someone create and upload their own print profile for a model as a test?
That would be very nice - then you would know that there are probably geometries / models that the Makerworld slicer simply cannot process.
Just had one fail in past few minutes. I’ve a custom printer setup, so I changed to default, changed the settings to a default profile, and nothing works. Simple design, zero needed or wanted supports. (fits entirely flat on bed) Oh well
I got an answer from Makerworld
Here is an excerpt from the support ticket:
MakerWorld
2024-10-06 04:38:22
Thank you for your time and patience. Upon examination, it appears that the issue lies within our system and the model images.
If the model author deletes and re-adds the model images before republishing the model, the issue may be fixed.
If this approach is not feasible, please await our resolution of this matter. We are actively working towards optimizing our system and aim to fully rectify this issue in upcoming versions, allowing for the seamless uploading of print profiles.
We sincerely apologize for any inconvenience and negative user experience this may have caused.
Your understanding and support are greatly appreciated.
Best regards,
MakerWorld
The print profile upload is now working as expected.
I had several failed print profiles as a draft, which i could now publish.
