Currently trying to print on a p1s, the defect print happens on the same spot. I dried the filament, recalibrated, updated software, adjust slow down for overhangs and it still happens. I print out different version of this print (pokeballs) and it only happens to this print. Was working just fine but when doing a reprint, this happened randomly. Any suggestions would be appreciated.
Did you check if this point is the begining or end of the layer? Did you also try to rotate the print in the bed or change seams options? Maype a PA calibration also can help.
How would I be able to check if this is the begging or the end of the layer? I will try a different position and see if it still happens.
