I have been attempting to print these organic planter shapes on my X2D:
https://makerworld.com/en/models/859645-modular-green#profileId-2329258
The issue I am having is the corners are not printing correctly. The rest of the object comes out fine. This happens every time I print the object. I have tried using ironing. This did not solve the issue. I am using Bambu Iridium Gold Metallic PLA filament. Other than the ironing my settings are default. This is printing from the main (left) nozzle via an AMS 2 Pro. I may try switching the filament to the secondary nozzle to see what happens.
How’s the bottom look? Rough tops but only in the corners has many causes; but the most common is the bottom has detached and is starting to curl upwards - and now the “empty space” the print is supposed to be printing in, has stuff in it, and it smushes out.
So if thats the case, clean the bed, consider a brim or mouse ears, glue, test a different bed temp or a cool plate, break up the bottom of the model, etc whatever your useful tricks for adhesion++ are.
I have it working for the most part. I believe adding the brims helped. Interestingly this only seems to happen on the main nozzle and not the secondary.
