The rest of the print looks very clean, just this area around the seam is bad. It’s also on the inside wall.
Are you using scarf seam?
I was wondering the same thing. Almost looks like a bad scarf seam.
No, i am using default settings.
Have you calibrated your filament?
Did you manage to fix this?
Yes, i have. It was probably caused by printing the outer perimeters first. I haven’t had this problem since going back to inner/outer.
