Dear BambuLab Team,
TLDR : when Setting print setting Multi color/ SILK filament and Glow in the Dark filament, it is optimal when there is standalone setting by COLOR
for example if I want to combine 3D model with
PLA or other material with : Standard Setting
SILK using Outer wall Speed @ 30-60mm/s ish &
Glow in the Dark using 3-4 wall org 2mm wall
usually Wall/speed & other settings can be done by Settings of the “PARTS”
which if you design/set your 3D model with Parts, (designed to be colored & other) it is possible
But what I encounter is with Models from makerworld im expecting many people shares their multi color 3D model with color seperated by “Part” but its is not.
Often time I encounter its ‘painted model’
the only available settings are by filament settings.
Hence to have settings speed , wall & etc by color it is impossible
(all i know the only access possible is Filament settings , Temprature & etc)
I hope the this feature is possible or if anyone have any good idea all are welcome
Imagine all the multi color 3D model from makerworld all are open to settings by color if this feature is implemented.
Thank you
