Print shot inside back gap
When removing the object from the bed, it shot loose, right into the gap at the back, fell down, then rolled to the side and out of reach.
… What do I do omg–
Should I just leave it? Am I supposed to do something to remove it? If so, how do I remove it?? I hope I don’t need to take the entire thing apart??
If it was me (you are not me).
I would carefully turn the printer upside down to remove it.
Make sure anything that will fall off, does so because you took it off first.
Bambu provided you with 2 Allen keys for a reason. They also used uniform screws throughout the back panel. Only the poop chute screws are “slightly” different.
In a nutshell, it ain’t that hard, even a caveman can do it.
Here’s the P1S backpanel removal guide.
But just in case, here’s a video on how to remove the back cover on the X1, they both use the same sheet metal.
Stick a piece of cardboard in the back then tip the printer to the side. Hopefully, it will slide to the cardboard, and you can remove it. I would try that before disassembling. :thinking:
A vaccum cleaner might work as well…
I still vote for turning it upside down.
That is how you get stuff out of a baby, it should work for a printer!
Yeah, @Olias has the sensible and likely correct way, but, if you ask him, he would agree that for a baby, you turn it upside down and shake vigorously - it is the the only way to do things.
:rofl:
Omg I’ve had my printer for less than five hours and this happened to me too. I’m so annoyed.
