I having the same issue in several diferent Stl files.
Tha printing stars fine and after 30 minutes or so the filament stops extruding and the printing head continue to move like It still printing.
i am using an A1 with AMS. I am using the original 0.04mm nozzle and I am trying to print in a 0.08 layer heigh. I have tried with clogging detection On and off.
I have already installed a New MicroSD and lowered the temperature since I was already using the filament Max temp (220C).
usually that indicates a clog or a tangle. I know the A1 has tangle detection, I assume you have it on.
Thats a lot of stringing. Do you have the proper settings for the filaments, or is it wet? The can cause clogs and cause what you describe. Usually you’ll know you have a clog because you have to clear it. Hopefully others can give you a better idea. I’d start with those though.
That looks like a per-supported model to me, like for resin printing.
Those supports rarely work on filament printers.
My guess is all this is support related.
I tried lower printing temp (started with 220C and now It is 205C) but I am still having issues. The filament isn’t wet, but I am using It for a week now. I Will try leaving It on a dryer for few hours.
The issue looks like someking of clog but when I cancel the failed print and start It again It works wine (without the need to ‘unclog’ It).
Can you provide a link to the model you are trying to print.
It has been pointed out it looks like you have tried to print a model designed to be printed by a resin printer and NOT an FDM printer. Your A1 is FDM.
The technologies are very different and a model created to be printed with a resin printer will likely fail on an FDM printer.
Your prints appear to have significant stringing. Something I haven’t seen so bad in years and never on a Bambu printer.
What filament are you using, include the manufacturer, the type, the sub-type and colour. Are you using a filament with infused material, for example wood pulp?
The filament is PLA from a Brazillian manufacturer called GTMAX 3D. It is a PLA Plus brown, with no infused material. The Datasheet is in portuguese but the only information are bed temp (0 to 60C), nozzle temp (190 to 220C) and max speed 150mm/s.
I am including pictures of all my printing settings
Yes, strings & looks kinda melted, your too hot.
Try 210* or 215*.
Also, go back to the default settings & change just the temp, leave everything else alone.
Miniatures are hard to print till you get the hang of it. Also, depending on the file, you might have to use a .02 nozzle. So not something to start with.
Try some normal models until you get used to how things work.
If you will, try printing one of these model. This way have should have completed results & have a print to look at.
Converting STL files designed for resin printing to be used with FDM (Fused Deposition Modeling) printers is definitely possible, but there are a few key considerations to keep in mind:
Material Considerations: Resin and FDM printers use different materials. Ensure that the material you choose for FDM printing is suitable for your design and intended use.
