Printer almost flawlessly resumed after outage
Had a power outage. The resume almost worked. It was a 10 hour print that had completed 9h, so it was worth a try. Print was shifted by about 1mm. So close! Anyone know of a way to improve accuracy on a resume like this?
This is a known issue. it also happens sometimes on filament swaps during print. An old Reddit post helped me mitigate this. If I remember right, it has to do with the printer homing during the pause and it using those new numbers as the origin. I hope you can find it!
That is sad to hear. They finally fixed the filament run out layer shift for the P1P with the latest firmware. I even pulled the plug to test loss of power and that worked too.
Start complaining to BBL. :unamused:
