Hello.
I have a problem with different coloring on a part i want to print.
Main color is silver…and two buttons are in red and green. I colored th2m in bambu studio as shown in the picture. The preview is also correct. But when i print it, the buttons are still silver but the layers around the buttons,are in the correspondending color. Is this known bug or am i doing something wrong? I used the filling option when coloring the buttons.
Welcome to the forum.
̶H̶a̶v̶e̶ ̶y̶o̶u̶ ̶s̶e̶t̶ ̶y̶o̶u̶r̶ ̶f̶l̶u̶s̶h̶i̶n̶g̶ ̶v̶o̶l̶u̶m̶e̶s̶?̶
̶T̶h̶e̶r̶e̶ ̶i̶s̶ ̶a̶ ̶b̶u̶t̶t̶o̶n̶ ̶r̶i̶g̶h̶t̶ ̶b̶e̶l̶o̶w̶ ̶t̶h̶e̶ ̶"̶P̶l̶a̶t̶e̶ ̶t̶y̶p̶e̶"̶ ̶s̶e̶l̶e̶c̶t̶i̶o̶n̶ ̶c̶a̶l̶l̶e̶d̶ ̶"̶F̶l̶u̶s̶h̶i̶n̶g̶ ̶V̶o̶l̶u̶m̶e̶s̶"̶
̶h̶t̶t̶p̶s̶:̶/̶/̶w̶i̶k̶i̶.̶b̶a̶m̶b̶u̶l̶a̶b̶.̶c̶o̶m̶/̶e̶n̶/̶s̶o̶f̶t̶w̶a̶r̶e̶/̶b̶a̶m̶b̶u̶-̶s̶t̶u̶d̶i̶o̶/̶r̶e̶d̶u̶c̶e̶-̶w̶a̶s̶t̶i̶n̶g̶-̶d̶u̶r̶i̶n̶g̶-̶f̶i̶l̶a̶m̶e̶n̶t̶-̶c̶h̶a̶n̶g̶e̶
Seems there is something really odd as it has inverted the printing color for those layers. At first I assumed that perhaps the spools could have been selected incorrectly but the base of the model is printed correctly so that throws that theory out the window.
The spools for the color are correct. I double checked it.
Does no one have an idea or the same problem?
I have not seen that problem. Are the buttons separate parts in the model? If so you could try split to parts and color the buttons by selecting the filament for each part rather than using the paint tool, then assemble and see if will print correctly.
It is just one object. So i cant seperate the buttons.
I t seems like there is an inverted logic in the software.
Any update/fix for this? 8-22-24 and having this same issue. Cant figure it out.
Have you checked your flushing volumes? Often they can default to 0.
I have and It is set above zero.
So it’s it’s set to 1? Can you post a picture of your print and upload your .3mf?
Welcome to the forum. I’ve fast-tracked you to basic user status so you can post pictures and files.
Well thank you. I was using the auto calibrate feature so didn’t pay too much attention to it. I found the multiplier to be very low. I adjusted it up a notch and noticed that some of the numbers went from red to white in color. I adjusted it up a little bit more until the colors I am using were white. However, now I cant even get a printed first layer. I will have to put some more work into it later and figure it out. I appreciate the assistance.
