Hello Community,
I am new to 3D printing and have already successfully printed a few models.
Now I am having problems printing at higher speeds. I am currently using normal PLA from Jayo. If the print speed is set to standard, everything runs perfectly, no problems and an absolutely clean print. But if I increase the speed to “Sport”, the problems start immediately. I also waited until the first layers were printed to ensure a proper base. Furthermore, I have not noticed that the model detaches from the print bed in any way. After printing, it sits very firmly. I use the “Smooth Plate” from Bambu Labs for printing.
I use the standard profile for “Bambu Labs PLA Basic” for printing. I also tried increasing the temperature from the standard 220 degrees to 230 and 235 degrees after setting it to Sport. This did not bring any improvement either.
Here are a few pictures. In the last picture you can also see the problem layers from the side where I had set to Sport. The remaining layers were printed on standard without any problems.
PS: And yes, I know that I forgot to remove the starting line at the front of the plate when I started printing. But this is not the cause of the problems, the printing errors in Sport occur in all models that are printed.
Kind regards and thx for any help
