Basically what the title says, every layer my printer will go to the purge if i dont enable by object feature. My problem is that when trying to print two objects with a bigger size the collision space makes it impossible and by layer i just have the problem of going to the purge every layer making the print of a worse quality and delaying the time to print.
Do you have the time lapse activated? If so, disable it.
Yeah thanks i gues that does the job. I still would like to know if theres an option to not show this travel in the slicer when during printing just doesnt do it. Changing the print to by object instead of by layer does it but of course if you have multiple big items you cant do it.
I think the setting you are looking for is âSmooth Time-lapseâ.
If it is enables, the printhead moves over to the wiper to get it out of the way of the model while the camera takes a picture.
The reason you donât have a problem with âBy Objectâ mode is because the timelapse doesnât work in that mode.
As ElektroQuark say, disabling timelapse completely will fix the problem. Or, if you still want timelapse videos, enable it, but disable smooth timelapse.
Have you tried turning off Timelapse and turning on zhop?
You are not really getting me. As @ElektroQuark said if you dont enable time lapse when sending the design to the printer, during the print the extruder will not move to the purge, but as you have to do it (not enabling time lapse) right when you are sending it to the printer you cant really see what the travel will be in the slicer so it makes it a little chaotic if you want to see what the print travel will be like. But appart from that problem solved.
@guzmix Did you solve this? Iâm having the same issue, where the extruder purges every layer or so. As similar to your case, this doesnât happen only if I am printing one object and sequence is set to âprint by object.â Also, want to indicate that Timelapse is set to âsmoothâ and i click âTimelapse offâ when sending to print - any help is much appreciated.
I am picking up what you are putting down. LOL
Did you ever find a solution for the secondary problem of seeing the non-existant travel paths on the preview screen?
I have the same problem. It shows the travel lines in the slicer and goes to purge every f-n layer ![]()
camera is turned off
