printer noisy when moving in a circle. is that normal?
If the shape isn’t a true circle and instead lots of short straights then yes.
If you lower your acceleration the noise will go away, if you can export the original object in a higher polly smoother circle this also resolves it.
Ok thank you a lot. ![]()
