Do anyone else have this issue? After a print is finish the printer goes offline to whichever the computer that sent the print. If go to a different computer running Bambu Studio, the printer is online for the new computer.
The only workaround has been to logout and login back in on Bambu Studio. And all of a sudden, the print is back online.
I know the printer is connected and is online the whole time. It is just some bug in Bambu Studio. Does anyone else have a more permanent solution?
Once I print from Bambu Studio on my macbook, it shows printer offline until I close the program and re-open, but that’s all I have to do to solve it at least.
That is my point. It should not take the printer offline after a print. It gets quite annoying having to close the Bambu Studio and reopen it. As I mentioned above, logging out and back in accomplish the same things.
And this does not happen on some of my other computer. There should be a way to refresh the printer without using workaround.
I’m now facing the same issue — every print results in the printer appearing offline until I power cycle. It worked for the first 3 days of it’s life and now constantly goes offline.
I can say it is not the printer disconnecting from the wireless router or network. Because if you have a second computer, you will find that the printer is online. I have also reboot the printer and Bambu Studio that you initially used to send the printer will show it offline. But any other computer will show the printer online. It is a Bambu Studio issue. That is why closing the program and restarting works. Or logging off and logging back on. Both work around works. But both are annoying.
Hi this happened to us yesterday and although the log out and in has worked once it’s now offline again and that fix isn’t working. Has anyone found a better/permanent/alternative fix please? Just keeps saying offline or unable to connect but I can see it’s on the WiFi as is the laptop and phone that I’m trying to send prints from. TIA
