Printing from External Spool/Spool Holder stopped working
For some reason if I load filament from the external spool, my X1C still thinks it should try to use the AMS. It will do the startup just fine, even print the purge lines along the perimeter, but when it comes to the actual print, it gives me
Please pull out the filament on the spool holder from the extruder or check if there is filament broken in the extruder, if AMS is to be used later, please connect PTFE tube to the coupler and click the “retry” button. [07FF 8003]
Before I print I uncheck the Enable AMS option. I’ve checked for clogs, etc, and I can print with the AMS just fine, but sometimes I have filament I don’t want to send through the AMS, so I’d like to get this working again.
I’ve also tried unplugging the AMS but then it gives me an error when it tries to print.
Failed to get AMS mapping table
FWIW I got that exact message when I forgot to uncheck “Use AMS” in the slicer upon sending the print. I’ve also been able to just unplug the AMS’s and plug them back without restarting printer. Are you running latest firmwares?
BTW does the slicer’s idea of what type/color is loaded from ext. spool match the filament for the print?
Nope, made sure I unchecked that and have tried multiple times. I’ve tried unplugging the AMS and restarting the X1C as well and it gives me that second error.
Everything works fine with the AMS, just doesn’t want to print from the external spool holder. :frowning:
And here’s my firmware
Oh and sorry, to answer your last question, yes. I added it in the Device section and then selected the exact filament option in the print settings for that spool.
How many colors does the model you are trying to print have?
The printer issues this message for the purpose of making sure that the plastic is being squeezed out of the extruder and confirming this. It’s not a mistake. If you do not confirm, the printer will try to load the filament into the extruder again
Just the one color.
Regarding that error, I think you’re thinking of the one when you load the filament. This one occurs after I’ve started the print, and it has ALREADY printed the purge lines along the edges of the build plate. For some reason after it does that, it think it needs to change filament and is issuing that message. I confirmed this yesterday by pulling the filament out after receiving that message and it started loading a filament from the AMS, even though I unchecked “Enable AMS” and made sure that the filament I had selected when choosing to print was the external spool holder filament.
I’ll give it another shot later today or tomorrow and see if I can get a video of the issue.
I have the same problem. The only way I can work around it is to delete all but 1 color from the filament list. I should not have to do that. I am only printing a single color from the external spool. I like to define projects that may include several colors for different plates, but when I do I cannot get the print to go successfully from the external spool.
I am having a similar problem. When I run the prints through AMS it is just fine. But when I try to run from external spool it doesn’t work. When I start the print, keeps trying to feed filament but it never happens. It is weird because when I load or unload the filament it works fine, purge the filament and even works when I manually purge. But when it is in the print process it doesn’t work. After several minutes of trying to feed the filament I get a message saying that it is no possible to sync the AMS (which is suppose to be disable).
Sometimes it works when I stop the print, go back to the AMS synchronization, select the ext spool for mapping and try again. But now it is not working at all.
I’m having the exact same issue after updating the firmware to 01.09.00.01. Had no issues printing from the external spool before this.
Yes, today I downgrade the firmware and now is printing fine from the external spool.
That’s a bit strange. I do a lot of printing using an external spool, though not directly—it’s routed through the AMS HT using the external spool bypass. Maybe that behaves slightly differently, but it definitely counts as an external spool setup.
