Printing just freezes
I’ve only had my P1S about 2/3 months. In that time I’ve had a few small issues but nothing I wasn’t able to find a fix for. This one has me stumped. I did look on forum to see and found a similar issue so I will try what was in there but in case that doesn’t work I want to be proactive and see if I can get some help
Only thing I have changed is my nozzle, got one on Amazon instead of Bambu. It’s been printing fine even with the replacement nozzle until today. I send the file to print. It downloads with no issue, starts heating everything up like it should and then just stops at “heatbed preheating” as shown in photo even though the bed is heated. Any suggestions would be most appreciated
Hi @Obiwan,
Welcome to the forum.
The issue is to generic so some suggestion to eliminate a few causes:
  1. If you dont have any data (e.g. AMS k-values) just reset your printer, calibrate and try again.
  2. If you do, check if the firmware is updated, update if necessary, hard reset the printer and recalibrate.
  3. Replace the memory card;
  4. Update the slicer if necessary; try printing another file.
Let me know if the issue persist.
Thanks for the tips.
So I did a factory reset, calibrated and did the self test and it all went good.
Replaced the SD card with a new one
Firmware is version 01.06.01.00
As for the other things you asked about, if you tell me where to find them I’ll happily provide.
Currently trying a brand new print and it’s been sitting on same screen for 5 minutes which never happened before. And has yet to start the new print
I am sorry it didnt work.
At least that eliminates common causes.
I am lost with this one. The first image shows that the nozzle is still heating … but after 5 minutes, it isn’t usual to be stuck.
  • Since you replaced the nozzle, double-check if the cables are firmly connected at both ends or return to the older one.
  • As the self-test doesn’t show errors, I will assume the printer is working well. In that case, the issue can be in the file, communication, etc.
    A straightforward test is without using the app or studio, i.e., using the printer display, printing one of the cache files that come by default in the printer memory, e.g., benchy, memory card holder, etc.
    To identify its failure stage, please pay attention to the printer’s behaviour, such as toolhead movement and temperatures.
    If this one gets stuck, too, it shows that the issue is with the printer.
  • If all that fails, open a Trouble Ticket with BL support or use their new service to chat directly with the support team. You already have plenty of info to share. At the same time, while waiting, inform us so we can try to give other tips.
Does the printer hang when printing one of the prints that is included with the printer?
If you don’t have them, they can be downloaded here.
https://wiki.bambulab.com/en/general/bbl-printer-internal-sliced-files
So I have tried 3 prints. 2 of my own and one that was preloaded and the same thing happens with all of them. I did open a ticket so hopefully support has some answers for me. I appreciate all the ideas. It’s just crazy how one day it just stopped.
The log files should give them insight into what it happening.
Hope so. Well now I just noticed a new problem, which could be the cause of the overall problem. The heatbed stays hot. She once I made this post I just had the printer on, but nothing printing of course due to the issue. Went into the app and check on the printer itself and the heatbed was as hot as when you would be printing. App said 65c. If this new information gives anyone new ideas to try let me know. I of course have no shut off the printer as I don’t want or need the heatbed in n all night.
I had this problem right now, print stuck at ‘heated preheating’ 54/55 degrees.
The problem started when I added a height range modifier to slow the printer down at the end of the print. The reason being that the shaking of the printer at the top layers would knock over the objects and I did not want to add a brim (because it left marks on the Silk PLA).
Somehow this caused a corruption in the .3mf file (I think). I started from scratch with a new project in Studio, added the stl’s, re-applied the height range modifier and now it works again.
All the other options (resetting, formatting/replacing SD-card etc.) did not work for me.
Hope this helps anyone.
@Obiwan
Hey, Any updates? I’ve got the same issue with my P1S now. It is getting stuck in Bed Pre-heating and will fail to start the print?
Did you recently upgrade firmware? Many people have found issues after updateing.
I just had this issue with a new P1S when trying to print a file from OrcaSlicer. After swapping to Bambu Studio I was able to start a print, however the printer is still reporting the bed temperature as 54/55
I had this issue and switching to the latest version of Bambu Studio (2.0.3.54) seemed to fix it. As the above person said, it is still reporting 54/55 as the temperature.
All fixed. It was actually an issue with the bed itself. Bambu sent a new one and it’s been working great. Thanks everyone for the advice
upgrading Bambu Studio solved the same issue for me – thanks for sharing!
For me it was the combination of the firmware upgrade and using Orca Slicer. I downgraded the firmware and the issue was resolved.
Possibly using the newest firmware with the newest Bambu Studio could solve it too.
this one worked for me too!
I had the issue now as well, came from holiday, updated prinster (P1S) and coudnt print, loaded my print in Bambu lab instead of Orca slicer, and it works. So looks like new update has issue with Orca slicer. Didnt try to find if there is update for Slicer yet.
Same problem and updating Bambu Lab Studio it was solved!
I had this issue today and I just flashed to 1.08 and it was fixed(I had never updated from 1.07). Seems like the act of flashing, whether forwards or backwards seems to do the trick for most folks.
