So just got the new REPLACEMENT printer and got rid of the old POS that I first got and things are going better, if I do say so myself…
So I print lots of PA6 and I use the HT to dry and keep it drying while printing. I am using the manual feed hole and very short PTFE tube. The spool ran pretty good until the last bit of the roll. It is a plastic spool. So this is frustrating as I have a print I need to finish but the printer does not have the strength to pull it. i have pulled it by hand and there is no tension on it. Bambu question? can you not make an extruder that could be set to have the sensor pressure modified slightly to over come this?
Get the TPU Assist module, it makes any external feeding a lot easier.
Ok thanks i will give that a try
Maybe a bit on the side, but do you do any adjustments when using it with non-TPU materials ?
Nope, I haven’t made any adjustments. The default setting seems to have worked OK.
Nice to know, that module kan do more than TPU
(Might not stand up to fiberfilled, need to look into that.)
Allegedly they will fit a X1 hardened steel gearset, although I haven’t verified that yet.
