at the last Bambu filament order is the PC filament (without additives) noticed. according to the specifications in the data sheet, the material is very interesting for technical components.
after unpacking it was dried according to instructions (ok my dryer makes only 70 degrees, but dried for 20 hours). In the X1C inserted it is immediately recognized, there is also the filament to select, fits so far.
The first parts are printed in standard settings, then the speed and acceleration was drastically reduced test, but the result was significantly worse.
What could be the problem?
Thank you
Best regards
Daniel
