Printing Threads in ABS
Greetings,
I need to design a covering for a coilover adjustment cover for my car.
It will be basically a grommet in a hole, with a threaded exterior, attached with a nut.
This can be made fairly large (25mm).
I’m using SolidWorks to test some thread designs. One of the thread profiles provided is SP4xx - bottle.
So, I made a shaft 12mm in diameter and did an extrude. Looks like this:
The thread profile looks like:
Going to print this using the standard 0.20mm Strength @BBL P1P profile, it looks like this:
Definitely not the same.
How can I tweak this, so the profile is more like what was designed?
Thanks in advance
what is the distance between thoses lines? did you used 0.4mm noozle ?
I would suggest editing your .20mm setting down to .16 and then down to .12 to see if your threads come out smoother. Also you might try using the variable level option in studio to see if cleans up a bit, good luck!
I print a lot of threads in my designs. There really are only two secrets.
  1. Use as fine a layer height as you can. 0.08 is a good place to start.
  2. Always print the part vertically and make sure that supports are enabled. I found that changing the spacing from the default of 0.35 to 0.70 leaves a generous gap that make the supports easier to remove. However, if you have a shallow enough slope <45 degrees, the slicer may not generate supports indicating that the slicer predicted that the filament would not need them. You can change that angle in the supports section.
Here is where the angle and XY gap distances may be found.
Notice the two examples here. AT 0.28 layer height the slicer wants to add supports. at 0.08 layer height they aren’t needed because the layers are much finer.
Here are some other settings that help. Concentric or Archimedian Chords will ensure round flow paths. Also, use of scarf joints will greatly help.
Feel free to play with this M12 bolt and nut. This nut and bolt conforms to the M standard and actually works with metal real world counterparts found in your local hardware store.
Nut M12 x 1.75 mm Thread, 12 mm Long example.3mf (689.3 KB)
I used this example to practice designing threads in OnShape to see what would an would not work. I can say that even when I had perfect print, I still had to cut the threads either with another plastic printed part or with an actual metal tap or metal nut. A few turns back and forth really made the difference but be careful of the tolerance. If your bolt is too fat, it will break off. In that case change the contour XY tolerance to slightly smaller.
One last tip, after you’ve work the two parts together with a few sample turns, a dab of PTFE lube, the same lube you use on the printer, is the final step of making smooth threads. But do this last as you want the threads to cut each other first to wear off the hot spots, then add the lube.
Thank you.
We’re headed out of town tomorrow, but I’ll look at this when we get back on Monday
chris
So, the 8mm nut bolt file you provided went wonky in a big way on my P1S.
I dropped back to my design, and changed the thread to be a lot smoother. All the gullies and flats were filleted (SolidWorks did a nice job here).
A project was created using your suggestions, and it printed beautifully.
So, thanks for the assistance.
chris
