Printing with polypropylene (PP) filament and Magigoo PP
I frequently see questions about printing with Polypropylene (PP) filament. I see there are some other threads on this here, but I wanted to share my experience.
The filament I use is Braskem PP - there are other choices, The first issue one runs into is that Bambu doesn’t offer PP as a filament type choice, so you must pick a different filament type to use as a basis for a new filament profile. I used PETG, but perhaps it would be better to choose a more unusual filament type, such as ABS.
PP loves to stick to itself, and nothing else. It won’t stick to any normal build plate (there are special PP build plates out there), and typical adhesives won’t work either. It will stick to clear packing tape, which is almost always PP, and I started out doing this, wrapping a smooth plate with the tape. The downside of this is that the print sticks VERY well to the tape, and it’s annoying trying to cover a build plate with the tape. It does work, though.
I recently acquired a tube of Magigoo PP, an adhesive specifically designed for PP and nothing else. The first several times I tried this, using the Engineering plate as a base, failed - the print would start working loose after a few layers. I was about to give up when I decided to try using one of my Lightyear G10 plates. This was more promising, but it took several more tries before I ended up with settings that worked.
Recommended nozzle temp: 220-240
Print temperature: 230
Bed temperature: 70
Cooling fan speed: 30
Chamber fan: off
Aux fan: off
Max volumetric speed: 12
I applied a rather thick coat of Magigoo PP, but this did work well and the print stuck. The part I was printing was relatively small, so I added a 5mm brim that I think helped. You could probably use a smooth PEI plate as well.
What build plates work for PolyPropylene?
I have been using the Engineering plate, but now you can’t buy replacements from Bambu.
I got no adhesion at all on the smooth PEI plate.
I think a hot plate works well for the PE, and the PP but not sure if it needs to be 110C, maybe I will try the 70C you suggest.
Chris
I strongly recommend Magigoo PP (a formula specifically for PP). You can use this on a smooth PEI plate.
My Bambu Lab has a Generic PP profile, so I started with that. It took a little trial and error but by increasing the plate temp on that profile to 80, and using Magigoo PP I was able to successfully print two pieces, on my A1 mini! I used a Cryogrip Pro Glacier plate.
I experimented and can say that 80 without the glue does not work. Neither does the profile default of 55 with the glue.
I used Eryone PP which says it has a plate temp of 60-80. The larger piece (6.5hrs) did lift a little at the end but not enough to ruin it. I also did try 70 instead of 80 with that one.
I’m going to experiment with more brim today as I re-print it for a friend, as well as going back to 80 and maybe turning off the fans. I’m not quite sure which fan setting to change yet.
It won’t let me embed pics or links here but I did post some to Reddit (same username there)
What was the K Factor you set for Flow Dynamic Control?
Has anyone tried preheating there chamber and see if that helps?
I used the default (0.020 I believe). I am however doing a manual calibration with it right now and I will let you know my results!
I think I was getting Flow Rate and Flow Dynamics mixed up
For Flow Dynamics I just use the automatic calibration when it starts printing
For Flow Rate I ran the manual calibration and I think I’ve settled on 0.93 as the best but I originally just used 1.0 and they are very close.
Thank you. I’m yet to try this PP for the first time and there’s a roll on it’s way as we speak :-). Will keep this info at hand. Cheers.
May I ask the use case for polypropylene filament?
It’s flexible, strong, and has unmatched layer adhesion. I have used it for hinges and cases, but admit that I have not done more with it. It is very much a specialty filament.
I tried several things and some were sucessful others less. Like using packing tape and I got myself some PP print sheets which are self adhesive and need to be put on a print plate. They itself produce well results but also tend to get off the build plate and they leave some PP on the printed model. So overall that was not what I wanted to have a clean print.
I also worked with the Magigoo PP glue and it worked very well. Prints have been successful. The issue with the glue was always, it is not possible to spread it even over the surface and it will leave “glue marks” on the model. Works but does not fulfill my expectations. I tried to dissolve the glue with alcohol or water to get it more evenly spread out, result was less adhesion and 50/50 successrate. Plus a lot of fizzling around until able to start.
My solution to successful PP printing on my printer (H2C): I ordered a Pr*sa PP build plate, for the H2C the one for the Core L works - it is a bit too small and the printer checks 3 times prior printing for the QR, the alignment etc. so it throws some errors. At the end, the result is perfect. Every print so far (8-10) came out very well. The print plate has a light structure, less than the standard Bambu build plate. That is what I have been looking for. No glue, just print with great result. The H2C itself doesn’t struggle with PP at all, even from the AMS HT it works.
I would hope that Bambu releases a PP print sheet at some point or some of the 3rd party providers which at least fits physically on my printer. But well, it is not the everyday filament and some manual is ok.
I use PP for mainly lids and molds which come close to food. It is very resistant and can be cleaned in the dishwasher.
