Problem connecting bamboo studio and x1
Dear All
we bought a printer for our company… there’s no way to connect the printer to the bamboo studio due we have the printer in different Vlan… there a way to make it work?
Check for any ports you might need and route between the VLANs, it definitely works.
Is a network trick ;).
If your default route points to an IP address on the same router that should work.
Hi
network is full routed… I can ping… but the slicer of bambu cannot find the printer… seems should be all on the same vlan there a way to force manually the ip address?
Did you manage to find a solution to this?
We are in the same situation.
We bought a printer and cannot get it to connect from our wireless vlan.
