Problem of separation from the table, Layer slipping
Hello friends. Please help me solve this problem. I am losing a lot. I have a 6-hour print. It has thin edges and is 200 mm long. Towards the end of the print, the object separates from the plate very little and causes layer marks. I cannot put my product up for sale like this. I applied glue to the plate. I adjusted the X Y Z axis belts. Sometimes it makes this mistake, sometimes it doesn’t. I print with A1. I have another one of the same machine. I get the same print on it, but it doesn’t have any problems.
I am also facing similar problem on my A1.
Your prints are warping because they are cooling off too fast as they are being printed. The plastic shrinks as it cools.
This is why some printers are fully enclosed.
Eliminate all cold drafts. If you’re printing in a colder room, turn the thermostat up. Or, take the cardboard box the printer came in, empty it and turn it over and put it over the printer when you are printing, make a low-budget enclosure for your printer.
Thank you. The printer was on the floor and I noticed that it was getting cold air from the floor. Then I lifted the printer onto a table. I raised the room temperature a little and applied glue to the table. The print was completed without any problems.
