Problem print with printer x1c
Hello, what can cause such an ugly print of the X1C? Filament is not damp, settings are not (I have another X1C that does not have these defects)… what do you think could depend on?
Hard to tell without additional information.
  • Problem on all sides or only this side and the opposite side or just this side alone?
  • What was the orientation in the printer (X/Y, AUX fan)?
  • What kind of filament?
  • Does the printer make strange noises?
  • Did you already tension the belts?
  • Did you check hotend/nozzle/print head if something came loose?
If you have thin walled parts like this shell, I think you should make a slow profile since the dynamics of your part really aren’t compatible with high speed printing. Maybe make all of the speeds something like 50mm/s-80mm/s Avoid 120mm/s as that is close to the resonant speed of the printer.
