Hello everyone, i’m having an issue with the A1 mini that i’ve not encountered before. Trying to print a couch or sofa file in 1/6 scale, so I have to split the file
and put the 2 resulting parts on separate plates.
The split parts works fine, but when i go and slice the file, the parts disappear.
I’ve included 2 pics of before and after. I thought it might be a corrupted file, but
I tried a totally different file, and the same thing happens.
An
y ideas or tips? thanks,
Win
Pics are reversed, but I think you can see the idea.
I’m guessing the model isn’t a solid and the walls of the couch are too thin for it to slice properly.
Can you share the 3mf or model? Might be helpful to see it firsthand and try and replicate it.
Try either selecting detect thin walls on the Strength tab or setting the wall type to Arachne under the quality tab. You have to pick one or the other as the slicer will not let you select both of these at the same time.
So, it appears that after splitting the file I need to right click on it and choose “split to objects”. After doing that, it sliced and allows me to print both parts. Thanks so much for the response.
