Hello.
This is my first time posting here.
The following are some of the problems I am having right now
As an example, create data with a dropped alphabet “A” and place and slice it towards the build plate side.
In this case, as you can see on the screen just at the bridge point, the bridge portion is generated with a slightly larger offset.
On the other hand, if you slice the dropped area with a color fill, the bridged area is generated without offset.
I know I should just say that the bridge portion is not offset significantly because it is an uncolored portion, but can you think of a way to fix this?
I would like to print without support settings if possible.
Also, color painting all of that layer is not desirable for the design.
I have contacted Bambulab technical support but have not received a reply.
