Problem with chamber temperature measurement
Good day to all!
I have a problem with the X1C printer - the chamber temperature is not measured. More precisely, the temperature even on a cold printer has a value of 60-61C. When printing, the temperature jumps from 54 to 63C.
Additional observations showed that the temperature jumps as the printhead moves. When the head is quietly standing still, the temperature is always 60C.
What could be the reason?
Thank you!
Where is the temperature sensor located in the printer chamder?
Here you go, hope this helps. The sensor is located on the button board which sits on the top right, below the 2 buttons.
Thank you very much!
Thank you friend! With your help, I found the cause of my problem - the connector on this board is partially broken.
