How to remove the filament (TPU 80A) here? It’s stuck. And I simply do not understand how this could happen.
I can’t move the extruder gear and I do not want to pull to strong.
Is there any chance to turn the gear without disassembling everything?
Solved it myself: Hat to push the Extrude Buttons and pull the filament very strong. It was very thin then and it was removed from the gear slowly. Puh.
I think I got it figured out. I believe it’s a pressure issue.
I started a test on my H3C after seeing your post. I’ve printed a lot of 2.85mm TPU with no issues at all. This is my first time trying 1.75mm TPU on the machine. I’m printing it a bit differently than their directions, the same way I do my PPA/PPS.
Filament: Bambu Lab 1.75mm 85A TPU
Toolhead 1
Bypass (with ceramic insert)
Load direction: Roll of filament so the TPU goes over the top and then straight down, not backwards like Bambu’s directions show.
I have a 2" piece of PTFE tube in the toolhead with a small piece sticking out to act as a guide for the TPU. I made sure it was pushed in all the way.
Test 1
0.4mm nozzle (standard)
Loading: It went in super easy and loaded the first time. Purge went great, dynamic flow calibration went great.
Printing: Immediate TPU all tangled up in the extruder gear. Tried again, same issue.
Test 2
0.6mm nozzle (standard)
Loading: Same. Super smooth.
Printing: Printing just fine. No issue on test print.
Print Profile: Standard Bambu 85A TPU profile, unchanged.
I used to run into random issues on the H2D with 85A TPU. Once I switched to a 0.6mm nozzle it went away. Bambu later locked out the standard 0.4mm nozzle in later Bambu Suite updates. You either have to use a 0.6mm nozzle or their special 0.4mm TPU nozzle.
0.6mm Nozzle
Started a 2nd print and it started just fine. I’m doing a benchy now. I’ll let you know what happens
Printed great
Update: The Benchy printed great for 85A TPU. I’m really impressed. Do not try and unload the TPU with the UNLOAD button. It gets stuck in the gears. I unloaded it like I do PPA/PPS. With the nozzle docked and not in the toolhead I just heat the nozzle up. The filament pulls out super easy and then turn the nozzle temp back to 0.
Bottom of CONE form test one
Benchy
