Problem with the smell
I set up my R1 in an upstairs bedroom, next to a window. The exhaust fan is vented directly out the window using a dryer exhaust window vent. I cut one small circle out of acrylic, left the R1 lid closed until the fan stopped running (after the cut), and yet the whole floor smells bad! My wife is not happy hehe.
Are there any tricks to this? The window vent I bought does have these plastic slats on it (see photo). Maybe they’re blocking some of the exhaust? Is this just what is to be expected with acrylic? Even cutting a small piece of basswood made the house smell like wood smoke, but at least that wasn’t completely unpleasant.
Help me so my wife doesn’t make me get rid of this thing :slight_smile:
Just as a general observation: it’s important to keep expectations realistic, as there will always be some degree of odor. The situation can usually be improved, but it cannot be completely eliminated. The reason is that the R1 is not fully airtight and, by design, cannot be. Otherwise, removing air from the unit would create a vacuum inside. That said, it’s definitely worth exploring ways to improve the setup and reduce the odors as much as possible.
However, a certain odor will always linger inside the device itself - even when it is turned off - burnt particles always ended up settling somewhere.
As a general point, I would check whether the exhausted air is being drawn back into the house somewhere else. This could happen through leaky windows, a door, shutter boxes, vents, other openings, or even through another window.
From experience, I can say that odors can travel surprisingly far around a building under certain weather conditions. Depending on wind direction, air pressure, and the layout of the house, smells can be carried around the entire property and re-enter the building at a different location.
Also, remember to let the fan run for a while - in other words, don’t open R1 right away just because it’s finished.
And just to address the most obvious factor: the location. Placing it right next to or in a bedroom is probably one of the least suitable options.
Often this is overlooked for the sake of convenience, with the argument, “We simply don’t have space anywhere else.” That may be true, but in many cases it’s better to make the effort to create a suitable space than to deal with odors on a daily basis. A better location can make a significant difference and is often more effective than trying to solve the issue with technical adjustments alone.
And finally, to address the most obvious thing: your setup clamped into the window looks extremely leaky. If it’s colder outside and warmer inside, the air will exchange through those gaps relentlessly, pushing the odors back in through every little crack and opening.
That’s simply how it works. Warm air inside, cold air outside, pressure differences, airflow… the smells will find their way back in. Because physics.
And if you want to pull out the big guns, the Air Purifier for the R1. There’s a reason why Bambu sells that as an accessory in the first place. I don’t know anyone who would willingly use a laser cutter in their living space (bedroom). Most people put it in the garage or basement.
This can be a challenge for a lot of household layouts. Imagine someone sits on your roof and barbecues. Depends on the wind, you are going to smell it, badly. It’s rather simple.
Since wife is concerned, you want a bulletproof solution, not relying on how the wind blows. Especially if you live in a single family 2-floor house with lots of rooms, shutting the necessary windows can be quite a chore. Short answer, get the E1 Pro purifier. Apparently it purifies well leaving the room decently pleasant. This way you don’t need to worry about wind and leaks and all that.
You also need to consider airflows: if a fan is pumping fumes outside the window, the room needs to have ways to let air in, ideally on the exact opposite end of the room. My laser room has 2 doors on opposite sides.
I also have the advantage that the rooms are conveniently arranged such that I only need to shut one door when I laser stuff to stop any fumes from drifting back into the house as long as nobody is playing on the balcony. I use a xTool P2S. Similar stuff. For a boost, I also added a powerful inline fan near the window to help pumping fumes out over long pipes.
Personally, I am able to do without a purifier, operated it without for a few years now, no complaints about smells so far, but there’s a lot that doesn’t translate to other house/apartments.
Years ago when I had a CO2 cutter in my home office the only way I could keep the smell down was if I opened one window and I installed an aftermarket 6-in fan venting out a different window. The factory fans on most of these CO2 cutters are not strong enough when you’re cutting wood. If you’re just engraving it’s fine. But once you start cutting the fumes get out of control. Here’s our shop setup to keep the fumes down. The bambu smoke filter going to outside would probably be fine, but you can get a cheap inline fan that will move more air.
Edit: also these fans work off of volume not pressure. So you want a larger fan and you want to keep your restrictions as low as possible. Also try to put the fan as close to the exit as possible so it’s drawing a vacuum. That way if you have a leak it sucks air instead of leaking fumes.
thank you for the thorough reply!
Here’s the blower / fan I used to run in my home office. I have felt around the wood and I would just slide the window to seal up against the wood. This fan is like a fifth the cost of the one we use in our shop but it is plenty strong enough for the short run in my office. The more 90s and distance you add it really kills the performance of the style fans
Power supply for it.
Also kind of realized I’m super sensitive to (the sensation of, not falling ill from) smells so I modded all my lasers to remote start so don’t even need to be in the room, not sure if it’s easy on the R1, but there are touch screen specific “finger robots”. “Do not leave it unattended” be damned :poop:.
(Ok, don’t scream, I still attend with PPE when testing new material/params to make sure nothing burns over)
If the room has the door closed and a carpeted floor, You may be creating a vacuum and just sucking the fumes right back in the window. If you are removing air from a somewhat sealed area, you need to feed in fresh air to replace it.
Stuff like opening a window on a different wall.
Edit: Sorry, other people already said this. They were right.
These are all great suggestions. I really appreciate how quickly this community responded. The bedroom isn’t being used right now, so I was able to move the machine further from the window, decreasing the number of bends in the exhaust tube (there’s now only one turn). I also added better insulation tape along the seams of the window insert. And I opened a window in another room nearby to encourage cross-ventilation. It is already much better! I might add that inline fan that was posted. That should really suck things out. I would buy the E1 Pro, but it’s on backorder till next month :frowning:
Do you guys think 2 inline fans would help keep the smell out of the room? I have the fan that attaches to the R1 then the 3 inch tube connected to a 6 inch duct that goes about 8 feet and out a window. The current 6 inch inline fan is right at the window pulling air from the duct that connects to the R1 3 inch tubing. I was thinking of adding a second 6 inch inline fan closer to the connection from the R1 to the 6 inch duct.
I’m still getting the smoke smell in the area of the R1. I have a Fan filter running a 4 panel Merv 14 filters and a Air Quality Monitor that spikes when cutting. I’m trying to figure out how to keep the air quality from getting bad. Would the Purifier E1 Pro solve this problem?
Has anyone used any fume extractors from amazon?
Thanks
Two fans don’t really help much and can even interfere with each other.
Think of it this way: one fan accelerates the air to about 2-6 m/s. Adding a second fan does not double the air speed. At best, the second fan can only maintain that existing 2-6 m/s airflow.
That’s why adding a second fan usually doesn’t provide much benefit. Instead, using a more powerful fan is often the better solution. For example, a stronger fan might achieve an airflow speed of around 10 m/s, which can make a noticeable difference.
Or, if air velocity feels too abstract, think in terms of negative pressure (suction) instead.
This is also why, for example, any existing external aux fan should be removed before installing the Purifier E1 Pro. If another fan is already in the airflow path, it can create additional resistance, turbulence, or unwanted airflow interactions.
A single powerful fan will always outperform two weaker fans that can end up interfering with each other. Especially in the context of a closed airflow system that uses ducts or hoses.
A second fan is not going to help much. You need to either reduce restriction on your system or get a larger fan. For our shop we had to go from a cheaper fan like I posted above to a more expensive fan that moves more air. We purposely ran 6" SDR pipe almost all the way to the machine to reduce restriction and maintain VOLUME. We had to do on offset at the roof so we bought 22.5* fittings instead of 45* to keep restsriction down. The 22.5* were $30 a fitting instead of $15. These fans work off volume and not pressure so the longer your 3" duct is the more its hurting the flow. You can try increasing that pipe size to 4" duct, extending your 6" pipe, or going to a better fan.
At the Shop we are using a much better fan but its also a lot more money.
Fantech FG 6XL Inline 6" Centrifugal Duct Fan, Metal Housing, 483 CFM, 120V
Most of the cheap 6" fans people grab on Amazon for laser exhaust just shove air straight down the pipe. That works fine if the duct is short and pretty open. As soon as you add a longer run of flexible hose, a couple bends, or anything that makes it harder for the air to move, those fans lose a lot of their power and the actual airflow drops off fast. And they won’t flow anywhere close to what they are rated for.
The Fantech is a different style. It spins the air outward like a blower instead of just pushing it straight through. That lets it keep pushing harder against resistance, so more of the air still makes it through when the duct isn’t perfect. That’s why it holds up better on a real laser exhaust setup instead of just looking good on paper in free air.
The E1 Pro: I have no idea how well that works. But for exhaust fumes I prefer the blower to create vacuum and be mounted as close as possible to the roof(or window). This way if you have a leak it is sucks air instead of causing a fume leak. None of these options will feel like a shop vacuum.
I went ahead and bought LF106 Laser Fume Extractor with Exhaust. Anyone know if I can connect it to the R1 with the fan that comes with the R1 or should I remove that one and figure out how to attach with out it?
Here is a link to what I bought. LF106 Laser Fume Extractor with Exhaust for Laser Engraver under 60W | 230W 212 CFM Smoke Purifier with H13 HEPA & Carbon Filter for Laser Marking, Cutting, Welding, 3D Printing and DTF - Amazon.com
You could consider making a one-way valve from preventing inward airflow when the fan is not on. A gravity closed “flapper” against a rubber seal at the exhaust hose’s exit. Of course this depends on you sealing the rest of the leaks and weather outside can’t over power the fan..
For anyone that is interested I hooked this up directly to the fan that we attach to the R1 and it works well so far. I ran test cuts on plywood and solid 5mm cherry and there was no smoke smell and pretty much no particles floating around in the air. I use a Air Quality Monitor and it showed normal the whole time only about 5 feet from the R1. I did not have this vented outside just directly into the room. I can vent it outside if I need to at some point.
This is great to know! I might just pick that one up. It’s a lot cheaper than the E1 Pro, too. Do you think you’ll have to replace all the charcoal pellets inside it fairly regularly?
I think it depends on how much you are doing and if you are cutting, engraving ect ect. From what I could tell it would not be that often.
Update I did a 1 hour cut and I did get a small amount of smell. My air quality monitor went to 0.5. The max it can go to is 2.5
I setup a curtain surrounding the R1 exhausting the fumes right out a window. I also setup a 6 inch inline fan that also exhaust right out the same window. When I pull the curtains shut I get no smell in the surrounding area. This is as close to zero fumes I have. My air only showed 1 ppm. I’m sticking with this setup. For now I just used some old shower curtains.
