Problems and unclean first layer
I am currently having problems with my P1S with the first layer and with overhangs. See pictures below.
What can I do or what exactly is the problem here?
This was not the case on the other side of the property.
A little more info would be helpful.
Type of filament?
Have you calibrated the flow?
Have you dried the filament?
How is your cooling set?
The first picture looks like you are slightly over extruding.
The second picture looks like the overhang is on the verge of too much.
The third picture looks like a seam.
Sorry, of course.
I used Bambulab PLA Filament. Filament is only in the AMS and is dried.
I took the profile from this object here and didn’t change anything:
Should Bambulab Filament also be calibrated? Or does a pressure flow calibration always have to be carried out with Bambulab Filament?
I have already calibrated the flow rate and have not changed any settings as the surface value 0 was the best.
I also calibrated the Flow Dynamics and did not change any settings as the lines fit.
Here is next picture, also Bambulab original PLA.
