I am at layer 60 of 400, 14 hours (not counting pauses) into a 69 hour (finishing 22:00 on 09-28 EDT) print. I am using the build plate as is after the last ‘…Failure 3’ print because I think it is ok and still has an undisturbed looking Printing Adhesive film on it. As previously stated, first layer is 0.1mm. I had a filament pile-up error (see photo red box) at around 10 hours, which I cleared about 12 hours later and resumed the print. I guess I am special somehow and get to see all the errors that can happen.
I figured that perhaps I got a bad spool of gray PLA Basic, so I am re-running the same build with the 7 parts being built with other colors in the AMS, green (4 large) and white (3 small). Along with using Support for PLA is white (which I think I am using for the last time ever) there are a lot of filament changes.
AMS shows 14% humidity after a second drying cycle. Build plate is 55°C and chamber temperature has been a steady 28-30°C. The first layer looked good (see photo). So, either the filaments benefitted from the 2nd drying cycle or the Gray is bad or arrived very ‘wet’ out of the package. I will print with it next to see how it does.
How are you making that measurement? If it’s just the reading from the AMS2, if it’s drying that number isn’t the filament humidity value. It’s a combination of the filament humidity value and how well the drying function is working.
The actual filament humidity value will probably be significantly higher.
An AMS isn’t the best place to use to get filament humidity values anyway. Even if drying is off, it’s sized for 4 spools and you should only have the spool you want to test in there or you see an average humidity value of sorts. One spool in a cavity that holds 4 will have lots of dead air and will slow the measurement big time.
The best way to get a filament humidity value is to put just the spool and a hygrometer - no desiccant - into a gallon ziplock or Praki-style polyethylene cereal box and seal it. After 30-45 minutes the hygrometer should settle on a value and that is the true filament humidity value.
Desiccant and active dryers both hide the filament humidity value from you.
Am I understanding you correctly - that this is support filament?
That means there’s something seriously wrong with your settings: Support filament shouldn’t be printed all over the print plate, but only as an intermediate layer. But maybe I misunderstood your comment?
Support filament is a very thin layer (support interface - see picture) that does not touch the print plate, except in rare cases.
Hi MZip, thanks for joining the fun and the bag test suggestion. Humidly telemetry off the AMS is all I have to go with. Have you had a look at how the gray printed in my earlier post? Is filament humidity the major culprit after all?
I am using it only as support interface. I haven’t had much trouble removing support material, so I don’t think it is worth using it for the print time it takes up. It only has potential value to me now if it provides for a better finish on the part over supports directly against the part, which I haven’t seen evidence of. I am currently monitoring the print remotely and that material is starting gum up. Damn.
Unfortunately the AMS humidity value just tells you your filament has more water than that number would indicate. Like I said it’s just a balance between water coming off the filament and water being removed from the chamber. More water from filament (wetter filament) and the number will increase. It tells you something but not much.
I don’t know if filament moisture is your issue, though. If you had an isolated reading on the filament moisture value I could tell you much more. But you are also trying to print something more difficult with that small nozzle size so my guidelines might be too high. I start seeing water issues in the 20-25% RH value range with PLA with the 0.4mm nozzle. 25% is too high for my setup. Different ambient environments and printers can have different results.
So can’t really say. Sorry about that. But I wouldn’t exclude water either. The AMS 2 should get you in pretty good shape if it has some time with that filament spool. I don’t have experience with the AMS 2 but people do say it dries PLA fairly well given enough time.
Update: I am now 1 day and 3 hours (layer 125 of 400) into this print. The printer is currently an hour round trip away from me and I have visited it multiple times to keep the print going. Particularly early on I happened to be there where I had to take actions (e.g. nozzle gumming, entanglements) that ‘saved’ the print. There are stoppages due to filament buildups about every 20 layers or 3-4 hours.The 0.2mm nozzle purges are so light and often times very stringy that they build up in the purge chute and block it. The chute is free and clear and obstruction free. Purges are also routinely kicked up to lie around behind and in front of the purge area and onto the plate. I am thinking of starting a new topic regarding issues I have seen printing with 0.2 nozzles.
I have noticed something that is annoying and I wish I could adjust in mid print. Whenever there is a switch to white, there is a 6-7 minute purge over the purge shoot consisting of 8 purges before printing resumes. The switch back to green takes no more that a minute with 1 purge over the chute. I must assume that since it knows that the filament is white that it goes to 8 purges over the chute to be sure that the white being extruded is pure white. Can anyone confirm this? I could go without that for this print. Is there a simple way to override that either before or during the print? I think that this print is sealing the deal on Support for PLA. I am done with it. I have a some sealed spools available for the cost of shipping if anyone wants them. It has never printed well and is even worse through a 0.2mm nozzle.
I have directly observed a few times the print head pausing near the purge tower on the way to it. After some moments, filament starts extruding in mid-air onto the build plate, which it then drags onto to the tower as it begins to lay filament on it. Really? Thoughts anyone?
This is by design. With the breakaway support being characterized by a low adhesion to the main material, they are in different “adhesivens categories” (filament setting). If they are different, the slicer knows it’ll have difficulty laying the priming lines across the towers scaffolding. So it forms a free falling “anchor” line even visible in the slicer preview.
Crude, but it can be really difficult to get dissimilar materials to attach on the prime tower.
With PETG on an H2, I have had better success by upping the PETG interface temp to 260° though.
Now that I zoom in, I do see what must be them in the preview, showing as short straight lines from the left and right. Although all the filaments are PLA differing in color (one is Support for PLA), they have some dissimilar adhesion characteristics? Sure, Support is meant to release, so it must be due to its layers on the tower. Answered my own question. I have seen the nozzle do a small circular dance on the edge of the tower before making its run on it. Currently at layer 143, 37 hours to go…
Yep, that’s it. The prime tower has had to see a lot of attention when the H2 was released. Quite a lot of interesting stuff to read (except unfortunately specifics as to the effect of different adhesiveness category settings ) Prime tower | Bambu Lab Wiki
Thanks! Although I just had filament pile-up stoppage. Managed to go much farther this time as printing is mostly green now. I think I’ll head over to clear it…
Hi @CarbonForge, I am halfway through my latest try of this print and it hasn’t been pretty. I am certainly curious what you think and how it would turn out for you. The .3mf is 19M and gcode file is 34M. Thanks.
I don’t know if you ever kept an eye on that interface process on the tower, but it raises the nozzle temperature 10-15C (could be the filament maximum temperature) above printing temperature before it lays the different material on the tower.
Indeed my lesson learned came from severe issues I had with my then new H2C back at the beginning of the year when learning how to doe PETG for PLA on it. Later on, issues disappeared but it is unlikely that I have always been meticulous about my settings
So sometime after the start of the year, the filament start gcode seems to have received a pretty important update. Quite good to see it evolving this way although a bit more documentation would be fun
Fortunately, it does not appear to be a straight 15°C temp increase as I had feared but a rather elaborate, filament specific logic chain.
Did you find where “flush_temperatures” are defined/calculated? I’d assume it to be the max filament temp, but I did not manage to track it down in the start or filament change gcode. Hope it is not fully hidden in M620 Unless there’s some documentation of M620 of course
I haven’t been digging too much into the gcode lately, but I know for sure that a lot of logic is based on the filament type.
I would love to see some more documentation on the gcode itself too. There are some comments, helping to understand what certain commands do, but a proper command reference would be great. Right now it is a lot of guessing, to what certain arguments exactly do, and if the controller can even make decisions based on certain parameters that might have been given earlier.
I have seen a command reference for the X1 series, but that was still based on Klipper I believe. The closed architecture isn’t making our life easier.
Hi @CarbonForge , I’ll have to figure out a drop option for the file. In the meantime, the 69 hour print has finished seemingly successfully (I’ll retrieve the parts tomorrow to find out). 39 of those hours are just because I decided to make 3 small parts of 7, white. So, the slicer gave the filament change from green to white 8 purges over the chute lasting 6 minutes for around 340 of the 400 layers. In short, if I had gone with just the one color green and did not use interface layers the print would have been 23 hours.
Hi @Gerrit, thanks for your interest and positive vibe. I’ve retrieved the parts and they are usable prototypes. I am pleased with the finish on the surfaces opposite the support side, which have the appearance of injection molding. The Support for PLA interface layer, which occasionally made for areas of smooth surfaces, did not fail to disappoint. Ugly scaring is found on all not-flat surfaces and on flat surfaces that also had some smooth areas. It often did not separate easily from the part requiring aggressive picking with tools. Someone will have to convince me that the material and or process parameters have been worked out before I ever use it again. The spaghetti is purge material that got kicked out by the wipe motion from over the chute. The 0.2mm purges are so wispy (as mentioned in the thread) that the reliance on gravity to guide them down the chute can be iffy. Combined with some purges that are stringy elongations they will clog the chute instead of falling free. The supports were ok.
