I have the problem with surface ironing of a 5 h print…
Here is the comparison without ironing:
Did you print that with a .6 or .8 nozzle…?? I think that might be your problem.
No, i printed both with 0.4
Found the wiki article:
Ironing | Bambu Lab Wiki
My problem looks like “The ironing flow is too small”
Does that mean i have to increase max volume metric speed in filament profile ?
I reduced it for the blue Geeetech PLA+ from 18mm³/s to 15mm³/s. That may caused the issue… confused.
This is the amount of material to be extruded during ironing. It is relative to the flow of normal layer height. Too high a value will result
in over-extrusion on the surface. Too small a value can also cause the ironing surface to not be smooth enough.
The ironing flow is too small:
The ironing flow is too large:
No, it’s the flow setting showing up below ironing when you enabled it in the slicer (might need advanced settings enabled). Default is 10% or so (depends on layer height profile) but you can try 20 or 25%.
BTW it looks like the infill is showing through as well, you could try another top surface unless that disappears with more ironing flow.
