Hi Guys,
the print quality is getting worse every print, starting 2 days ago.
i have been printing the same parts, with the same filament some time now. but now the top layer (I use ironing) has defect during printing. even swapped filament that has been dried before, but didnt make a difference. strange thing is that it is not consistent on the complete part.
So i printed a testpart, which i have a previous printed part of, and it failed in a specific area (see attached images). it’s a circle, and the left side of circle is perfect, but right side looks like attached picture.
Steps i took to try and solve issue: try to change filament settings, did filament calibration, changed filament, cleaned nozzle, swapped hotend, replaced ptfe tube to toolhead, did the bed leveling/tramming, checked extruder gear, adjusted tension, ran full calibration of printer.
I have no clue anymore how to fix this. Can there be another mechanical defect on the printer itself?
I noticed some play in the toolhead and the x-axis carbon rod assembly, but I don’t know if that is always the case.
When I print a circle, the left side of the circle looks good, but the right side looks terrible. I know for sure that this was ok before because I printed this part numerous times. But not only the circle is bad, other object surfaces too.
I print small and large circles, all flawless and perfect. I was very happy with the P1S and its print quality but all of a sudden things start to get very bad.
I sell these items, but at the moment I cannot print anything until I find a solution.
Bambulab P1S
0.20 standard setting + ironing concentric 20% line distance 0.22mm
Filament: bambu basic pla red + bambu matte pla black
top is old part, bottom is new printed part
