Problems with supports, possibly related to modifiers
First off, does it make sense to post questions about issues with prints here? I’m using an X2D, but I don’t know that it’s a problem specific to that machine.
I’m printing a design I created in Fusion 360, trying to print in ASA, and trying to use modifiers to print 100% infill in 3 specific locations for “clamps”. I’m new to Bambu Studio, and new to the ASA material. In the past, I printed several functional parts on a CR-10S, using the Cura slicer with “infill blocks”, and this worked well (these were all with PLA).
Here’s the print in ASA. Briefly, this is a fitting to connect EMT tubing, and the tabs with the holes are to clamp the tubing tight. The corners of the “clamp tabs” are getting messed up. By the way, this is oriented on the build plate with the flat part, where the 3 legs meet, down on the plate.
Here’s the same model, same 3MF file, the only difference being I selected black PLA from the AMS instead of the ASA. The problem is much less severe, but still there.
Before I printed the above in the photos, I got one perfect prototype print in PLA. That was done before I added modifier blocks in BS. So I think it may be related to that, but I’m clueless how it’s related, or what I can or should change about the modifiers to get it to print cleanly.
For troubleshooting prints, do you all usually include the 3mf model file? I can include that in a reply if that’s okay. I did not change much from the default profile - set to random seams; set “only one wall on top” to Not Applied; enabled support and set to “on build plate only” (although one of my attempts was without the On build plate only" setting); remove small overhangs = No.
Hoping I can get some ideas here on what’s happening.
Well, not related to the modifier blocks. I’ve tried a few variables. Printed in PLA again - very little roughness around the bottom edges - so the material is a factor. (Again, I’m new at printing ASA, so this may be the learning curve). Printed without the modifiers, in ASA - terrible again. I also tried changing the Threshold Angle for supports to 45, which resulted in a lot more support, but still had terrible torn out areas at the bottom edges.
I’ve finally modified the design to “taper” what I’m calling the “clamp tabs”. This doesn’t eliminate the issue, but greatly reduces it, and leaves me with a usable part.
But I’m still wondering how this could be fixed. It seems to have trouble supporting sharp corners at the bottom. I have this oriented on the plate in a way that probably exacerbates this problem. But I want this orientation to prevent the layer from aligning with the principal forces that the part will see in use. I also noticed that the auto-orient in BS sets the part this way. I’ve uploaded the 3MF, if anyone should be kind enough to look and give suggestions.
3-Way C v3.3mf (160.2 KB)
A bit more info in pictures.
Below is the attempt I made with no modifiers. Same issue.
Below is a redesign, tapering the clamp tabs down the leg further. Much improved, and usuable, but still shows there’s a problem supporting the downward-facing edges.
Next step - going to try painting on more support. Might be a nightmare to remove.
