Problems with the TPU Assist module
It’s been a while since I last printed with TPU, and I wanted to use the Assist Module on my H2C.
And I’m already running into problems...
- Loading the TPU:
The module is calibrated, and the TPU is successfully fed up to the extruder.
However, the "Load" function doesn't appear on the printer afterwards—only "Unload."
If I restart the printer, "Load" does appear, but selecting it triggers a notification regarding the "Filament Track switch," which is still connected.
- Feed speed:
When I feed the TPU in, the movement is jerky rather than smooth.
Is this normal?
It does stop once it reaches the extruder, though.
There is a "power adjustment button" in the middle, but pressing it in conjunction with the feed button results in no change to the feed speed.
