I use a A1 in a workplace where Ethernet is preferred to Wi-Fi for security and performance.
Additionally I have not been able to get more than 140 Mbps out of the A1, even with a WiFi router about 40cm from it.
The A1 and A1 mini have two Bambu Bus (BB) ports, with only one being used for the AMS Lite.
It would be a useful feature and a value add to have Ethernet capability through the 2nd Bambu Bus.
I imagine this would be through a Bambu Bus to RJ-45 Ethernet adapter and a firmware update to support it.
I would think those ports would be very low data rate. The connection to the AMS doesn’t require much bandwidth.
Bambulab is not going to open the firmware any time soon. That is a non-starter, sorry to say.
It is a hardware-software integrated system. That is what makes it work so well, but also frustrating. It is also the key to their entire business model. The CEO has said that when the current printers come to the end of their support life, they might offer the firmware. I think it’s pretty clear. That means there is no chance of them doing so sooner.
Hi, I am looking for a Ethernet solution for the P1S model. At my work we need to connect with a LAN cable. for now we are using a hotspot. I am also not able to use the SD card, as we are not allowed to use external storage hardware. Is there a solution for an upgrade to a ethernet module is this model?
I think an ethernet port is still much required from a printer, they all use 2.4 Ghz and that bandwith is already a mess with so many devices using that band. In a print farm I’d prefer ethernet every single time for the added stability
Wire is a more secure connection, not that it cannot be compromised. Also WIFI connections can be unstable in a ‘congested’ area, reducing bandwidth/data rate and sometimes appropriate router/repeater is not reachable. But such are the limitations of wifi in any application.
