I have a H2C with the cutting module and no laser. When looking in Makerworld under All Models then selecting the Laser & Cut Models and then setting the Modules filter to Cutting Module Only (selecting both Fine Point Blade and Pen options), there are a significant number of models which clearly don’t use the cutting module at all, a few I found are either pure laser, or laser + 3D print.
You might think that someone might mistake Cutting Module Only with the new R1, but that doesn’t make sense because they’d get stopped by only Fine Point Blade or Pen being the process options and not laser.
There was also this project:
which looks good, but the profile details says it was Blade Cut using Kraft Paper, so really it’s a photo of a laser engraving project with completely incorrect settings.
I’m really bringing this up because the Cutting Module has so few projects for it in Makerworld
that the project listings that incorrectly specify it block out the relatively few correct ones, and I think this deserves a correction sweep by Makerworld. I’m not saying the incorrectly labeled ones aren’t good projects, just that they should correctly follow the filtering in Makerworld so they can be found.
