Your Open Source Exporter Solution for BambuLabs X1C!
Prometheus MQTT Exporter that was developed in Golang and containerized in Docker. Once I bought this fantastic printer I had to have “all the data” on my printer. Unfortunately, there was little documentation online and summarized in forums/Youtube. I set out a goal to see if I could build an exporter. After perusing data on Youtube, Forum Posts, and slamming my head into Port Scans/MQTT options I was able to successfully pull out some data.
Thanks,
Tyler Bennet / Aetrius
Bambulabs Exporter - YouTube - Guide for people not familiar with exporters.
Hi! Would it be possible to get data to Excel/google sheets such as grams, print time etc. of each task? Using this “exporter”?
Welcome to the forum!
I don’t know if he’ll see this, it’s been almost two years since he posted anything here. I looked at the Github and it hasn’t been updated in two years either, but if you scroll all the way to the bottom he has his Gmail address there. That might be your best bet and contacting him.
I’m here…
Prometheus exporter by definition is just putting the data in the format of being able to scrape a Time Series Metric into a TSDB (time series database).
An alternative format for Excel would need to be it’s own project. I’m fairly sure someone has something similar already if you poke around the forums/github.
If you can’t find anything on the forums post back here and I might be able to fit this in some time in like march…
Has this been tested on the newest firmware?
Haven’t tried this as I don’t have a need for the Grafana dashboard, but it just uses MQTT to extract printer status so there’s no reason why it wouldn’t work from a monitoring standpoint. I use MQTT to monitor my printer and it still works with the latest firmware, as does my BLLED LED controller.
BBL only locked down printer control, not printer monitoring.
