Pros and cons of "purge into prime tower"
I installed Orca Slicer based on recommendations here. While checking Printer settings i realized there is one additional settings tab “multimaterial” which BS does not have. There is no OS wiki entry for these yet.
One of the settings i am interested in is "“purge into prime tower”. I think this can be possible in BS by manually selecting prime tower as “purge into this object” but can not be set as default.
The reason i am interested in is the volume of the poops which i have to get rid of. Prime towers are more compact that i will need less trips to common recycle bins which are four blocks away.
The cons i can guess may be;
Needs bigger prime tower>less build plate estate for printing.
Taller>more risk to topple>needs brim to avoid
More wasted filament if the dimensions are not set correct.
What is your experience?
does orca slicer let you check the “purge in prime tower” box? mine will not let me check that box and i dont know why or how to fix it so if you have any advice or know how to fix this issue i would greatly appreciate the help or incite thanks so much:)
