Purge line changes
Hello everyone, I recently updated my P1S and now when going through the start-up the purge lines look more like the X1C where there are 5 lines then the one L-shaped one in front with the corner one in the back. Before it was just the L in the front and the corner one in the back. Does anyone know how to get it back to the 2 original ones instead of the new style?
Thank you
Are you sure you haven’t accidentally chosen the X series in BS?
I have upgraded the firmware for the P1S and upgrade BS to the latest version.
I am still getting the “L” shape you mentioned.
No I did not but I did change the G-code months ago to turn the fans down slightly for noise reasons and for some reason the update messed with that. When I set it back to a default profile it was fine. Thank you for your help!
That is used only for filament calibration using the X1C’s laser. It is in the Machine Start G-code.
